All's well so far
- Home Phone
- All's well so far
All's well so far
30-09-2007 4:36 PM
Just like to say that I moved my landline to Plusnet's Anytime+ and so far everything has worked very well.
There were no hitches with the move that involved the line from BT and the calls from Talk Talk.
I was kept well informed by Plusnet at every stage of the process and it all went over as planned on the 19th of October.
I did find it amusing that within a day or so of placing the order with Plusnet that I got letters from BT and Talk Talk begging me to stay with them.
I do like the ability to look at any time at the call and cost history on the portal so that I can check the account whenever I need to, especially with having to call my son in Russia a couple of times a week.
Nice one Plusnet.
Nice one Plusnet.
Message 1 of 6
(4,992 Views)
5 REPLIES 5
Re: All's well so far
01-10-2007 8:30 AM
Good stuff, glad to hear you're happy so far.
Message 2 of 6
(632 Views)
01-10-2007 1:52 PM
I've been with Plusnet Anytime+ for about 3 months and have had no problems. The change-over from BT went smoothly. The calls history page is very good
It would be helpful if there was a facility to keep a check on overseas 300 minutes useage limit; similar to the one that was in place for the earlier 1000 minutes call limit. I believe this is being considered.
Message 3 of 6
(632 Views)
01-10-2007 1:59 PM
Yep, this is on it's way. I'll chase it for you this afternoon and see what I can come up with.
Message 4 of 6
(632 Views)
01-10-2007 3:20 PM
Hi guys,
The fix for this is in testing and should be rolled live by the end of the week.
Message 5 of 6
(632 Views)
01-10-2007 4:32 PM
Thank you, Mand.
Message 6 of 6
(632 Views)
