Adding phone numbers to Call Protect
- Home Phone
- Adding phone numbers to Call Protect
17-03-2021 12:22 PM
To add a number to call protect do I have to answer the call on my handset or can I let it ring until they ring off and then add it using 1572?
I'm unable to connect to 1572 although call protect shows as being active in my account.
Re: Adding phone numbers to Call Protect
17-03-2021 12:28 PM
Hi @benrm . That looks like a two-part question
If you want to add a number to the blocked list, unfortunately you do have to at least accept the call, although if you know it is fake/unwanted, just accept it, then close the connection without speaking, then you are able to 'add last accepted call to the blocklist'
What happens if you try to access 1572?
17-03-2021 12:44 PM
I get the message 'this service cannot be connected'
17-03-2021 1:07 PM
Ah - OK. In that case you need to contact Plusnet and ask them to remove/reinstall and activate it. This is a recurring problem with a simple solution.
17-03-2021 4:46 PM
@benrm When it's up and running, you may find this useful if you haven't seen it -
FTTC 40/10 Billion 8800NL
BT technician (Retired)
24-03-2021 12:35 PM
Thank you so much for the spreadsheet of 1572 options, very useful and hopefully will help me stop many nuisance international calls at least. I hadn't found my way into the Option 4 settings menu.
24-03-2021 7:49 PM
- Home Phone
