Adding mobile minutes for £3?
- Home Phone
- Adding mobile minutes for £3?
10-09-2014 1:48 PM
Due to the recent 26p charges showing up on our bill we feel it would be worth while adding the mobile minutes option but i don't see how we go about doing this.
If anyone can advise me on this it would be most helpfull.
Might also downgrade the internet package as we only get a max of 40/10 on this line so seems silly to pay for 80/20 but are the other packages still unlimited?
Re: Adding mobile minutes for £3?
10-09-2014 2:04 PM
You can change both of these from the 'Product Change' option after logging into the member's centre. Alternatively, I can do this for you now.
The broadband package you are changing to would definitely be more suitable for you as you cannot achieve speeds over 40mb based on your line. Yes, it will still be unlimited so use it as much as you like.
Thanks,
Matty
10-09-2014 2:17 PM
I did have a look in the options but i realy could not see where to change to the things i want hehe so if you are able to help me that would be great.
Just to be clear on what we are looking for.
We would like to change the internet package from 80/20 to the 40/10 product
We would still like the anytime call package and caller display
We would like to add the mobile minutes aswell.
Thanks again and i hope i have provided enough info
10-09-2014 4:35 PM
You should already have Caller Display.....is this the case?
Thanks,
Matty
10-09-2014 4:43 PM
Thanks again Mattyc you have been a great help and i would buy you a beer if i could.
12-09-2014 1:44 PM
If everything has been changed will i see the lower cost of £14.99 after the next billing date?
Thanks in advance.
12-09-2014 1:56 PM
From my side, it reflects that the fibre is due to change as well.
I am certain that you will see the benefit with the cheaper bill on Sunday. I'll send you a confirmation email now just for clarification and so we definitely have an internal log.
12-09-2014 2:11 PM
I wounder if my net has already been downgraded because i lost connection lastnight or should i say in the early hours (around 12.45am) and after waiting about 10 minutes for it to reconnect i noticed that my BT profile had gone up to around 38MBps
Below is a quick test i did just now.
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
32.14 Mbps
0 Mbps 38.34 Mbps
Max Achievable Speed
Download speedachieved during the test was - 32.14 Mbps
For your connection, the acceptable range of speedsis 30.67 Mbps-38.34 Mbps .
Additional Information:
IP Profile for your line is - 38.34 Mbps
12-09-2014 2:26 PM
In all honesty, I don't think anything would really be changed other than the billing element and name of the package. Your speeds certainly shouldn't differ.
12-09-2014 2:39 PM
The thing is as far as i remember all tests done seemed to suggest my line is fine so no idea what goes on lol.
Just odd how things reset lastnight and then i ended up with a better profile.
If it's possible would you be able to post one of them nice graphs that show the connection over a certain amount of time please, i think its called a radius graph or something along them lines.
12-09-2014 2:48 PM
<img src="http://community.plus.net/visualradius/generated/image14105296258156.png"/>
12-09-2014 3:10 PM
Thanks again.
- Home Phone
