Adding a telephone ringer
- Home Phone
- Adding a telephone ringer
14-09-2014 3:59 PM
I would like to add a telephone ringer. However I already have 4 telephones attached - giving a REN value of 4. The telephone ringer also has a REN value of 1 which if I connected it would give me REN value of 5. I've read that you shouldn't exceed a REN value of 4.
Is it possible for me to add a telephone ringer? Please would some kind person advise.
Message 1 of 8
(2,816 Views)
7 REPLIES 7
Re: Adding a telephone ringer
14-09-2014 11:10 PM
Not an answer, but - unfortunately, phones are rated "upto" with integer values - so a true loading less than 1 is certified as 1 - see also the wikipedia entry.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 2 of 8
(703 Views)
14-09-2014 11:37 PM
It's just a guideline - meaning basically that BT Openreach won't be interested if you complain of ringing problems and you have a total REN of 5.
Unless you have a particularly long line, chances are you'll be fine. Just try it and see - either it'll work or it won't - and no harm will be done in either case.
4C (ex-BT)
4C (ex-BT)
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 3 of 8
(703 Views)
15-09-2014 10:10 AM
Thanks. If having a REN of 5 won't cause any harm I'll try it and if it works fine. Unfortunately I do have rather a long line from the cabinet to my property which caused some issues when I first had ADSL and then fibre broadband installed.
Is there any device you can get which you can add to a phone line to increase the number of devices which can be attached?
Message 4 of 8
(703 Views)
15-09-2014 10:13 AM
Yes
A DECT phone - one base station and several hand sets
Message 5 of 8
(703 Views)
15-09-2014 10:18 AM
I would second Jims suggestion.
A DECT phone set with 2 or more handsets will still only take a REN of around 1. You can position the master base station near you phone socket and have the rest of the phones anywhere that is convenient.
Message 6 of 8
(703 Views)
15-09-2014 10:43 AM
Thanks. I'll do that. It'll save problems with having ringers etc.
Message 7 of 8
(703 Views)
15-09-2014 11:38 AM
You might want to look at the ones offered by BT with the call nuisance blocking system - you can use them to help stop cold callers / withheld numbers etc etc.
They cost a few quid more but well worth looking at for a long term investment.
Message 8 of 8
(703 Views)
