Adding a nuisance number to call protect
- Home Phone
- Re: Adding a nuisance number to call protect
18-09-2018 6:05 PM
I want to add a number to call protect, unfortunately, someone else called before I could get to 1572 to activate the block by using the 1 button.
Is there a way to add the number on line?
on 18-09-2018 6:15 PM - last edited on 19-09-2018 10:17 AM by Strat
No, one of the deficiencies of call protect
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
19-09-2018 8:24 AM
According to This link to the call protect instruction table, if you know the number you can add it manually (option 4 > 2)
Not tried it, and don't know whether your 'own list' replaces or is in addition to the 'recommended list', so a bit of experimentation required unless someone knows for sure.
19-09-2018 10:11 AM
Thanks for all the help, just going to wait until he phones again, probably today, as usual. and 1572 him.
19-09-2018 7:01 PM
Hi there and welcome to our community forums.
I realise I'm a little late here as you've got an answer already though it's probably not the one you'd like.
I believe we've passed feedback on in the past to our products guys about this.
Please do let us know if you have any other queries or need further assistance.
25-09-2018 2:12 PM
My diverted callers list is currently full according to 1572 but nowhere can I find how many diverted callers I can have any help would now be appreciated as I have had 6 unsolicited calls in the past 2 days.
25-09-2018 2:40 PM
The answer is 100 diverted caller numbers (and up to 50 VIP numbers.)
25-09-2018 2:53 PM
OK but did not find that on P/N site anywhere (Portal not loading correctly) however I may have over the time input 100 but no more that 15 numbers on VIP and that is saying it is full. Also where are the instructions for removing old and maybe duplicated ones to add new ones, again not found these on the P/N site anywhere.
26-09-2018 11:20 AM
26-09-2018 1:59 PM
That only shows call features not how to check "Diverted Callers lists" in option 1 and option 4 and also how to remove older numbers in the same.
26-09-2018 3:20 PM
That's the only option I've found too - you can only remove them one by one!
26-09-2018 7:27 PM
Not answering the question, how do I delete the oldest numbers diverted to release space and how do I check to see if I have inadvertently duplicated any numbers in both options with the total again in both options of how many diverted please.
26-09-2018 7:28 PM
How do you tell if they are the oldest numbers please.
27-09-2018 11:00 AM
The only option appears to be 'a short list of your least effective numbers' - whether these start with the oldest or are somehow ordered as to whether they have actually been used to block calls from that number I don't know.
Unlike BT's own call protect system Plusnet does not provide the facility to manage your lists online, so I can only suggest you make yourself a nice cup of tea, find a comfy chair, and stretch your fingers prior to working through and editing the list one by one.
27-09-2018 11:57 AM
Tried that (option 4, option 4 then option 5) start to listen but before the voice gets to the last digit I get cut off, so I cannot use that option
There is no list for option 1 as that is only to add, option 2 is to remove the last entry, so that will be the newest entry. If there is 100 numbers deleting them 1x1 will need more than a nice cup of tea.
- Home Phone
