Adding a nuisance number to call protect
popsrekrap
I want to add a number to call protect, unfortunately, someone else called before I could get to 1572 to activate the block by using the 1 button.
Is there a way to add the number on line?
14 REPLIES 14
MymsMan
Re: Adding a nuisance number to call protect
No, one of the deficiencies of call protect
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
JayG
Fixes: 6
According to This link to the call protect instruction table, if you know the number you can add it manually (option 4 > 2)
Not tried it, and don't know whether your 'own list' replaces or is in addition to the 'recommended list', so a bit of experimentation required unless someone knows for sure.
popsrekrap
Thanks for all the help, just going to wait until he phones again, probably today, as usual. and 1572 him.
Fixes: 1,600
Hi there and welcome to our community forums.
I realise I'm a little late here as you've got an answer already though it's probably not the one you'd like.
I believe we've passed feedback on in the past to our products guys about this.
Please do let us know if you have any other queries or need further assistance.
mort7890
Fixes: 4
@Gandalf
My diverted callers list is currently full according to 1572 but nowhere can I find how many diverted callers I can have any help would now be appreciated as I have had 6 unsolicited calls in the past 2 days.
JayG
Fixes: 6
The answer is 100 diverted caller numbers (and up to 50 VIP numbers.)
mort7890
Fixes: 4
OK but did not find that on P/N site anywhere (Portal not loading correctly) however I may have over the time input 100 but no more that 15 numbers on VIP and that is saying it is full. Also where are the instructions for removing old and maybe duplicated ones to add new ones, again not found these on the P/N site anywhere.
EmilyD
Fixes: 117
Hi @mort7890,
I'm sorry to hear that it's saying that your VIP list is full despite you not adding many numbers to this. Please have a look at the call feature page here for full instructions on using the Call Protect feature - you can find this under the "How do I use call features?" section.
 Emily D
mort7890
Fixes: 4
That only shows call features not how to check "Diverted Callers lists" in option 1 and option 4 and also how to remove older numbers in the same.
JayG
Fixes: 6
That's the only option I've found too - you can only remove them one by one! Roll_eyes
mort7890
Fixes: 4
@EmilyD
Not answering the question, how do I delete the oldest numbers diverted to release space and how do I check to see if I have inadvertently duplicated any numbers in both options with the total again in both options of how many diverted please.
mort7890
Fixes: 4
@JayG
How do you tell if they are the oldest numbers please.
JayG
Fixes: 6
The only option appears to be 'a short list of your least effective numbers' - whether these start with the oldest or are somehow ordered as to whether they have actually been used to block calls from that number I don't know.
Unlike BT's own call protect system Plusnet does not provide the facility to manage your lists online, so I can only suggest you make yourself a nice cup of tea, find a comfy chair, and stretch your fingers prior to working through and editing the list one by one.
mort7890
Fixes: 4
@JayG @EmilyD
Tried that (option 4, option 4 then option 5) start to listen but before the voice gets to the last digit I get cut off, so I cannot use that option
There is no list for option 1 as that is only to add, option 2 is to remove the last entry, so that will be the newest entry. If there is 100 numbers deleting them 1x1 will need more than a nice cup of tea.
