Adding Call Package
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Adding Call Package
27-12-2019 12:23 PM
27-12-2019 1:08 PM
Welcome to the forum. 😀
If you sign in to your account, then go to
https://www.plus.net/my.html?s=0&action=account_summary
you can then select "Change product" under "Other Links".
Select to retain your broadband product, then add the required phone plan.
The plan will start on your next billing date.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
23-04-2020 10:11 AM
When I add the call package, the sum payable quoted is more than what I'm paying now plus the £9 for the package. The end date is also extended so it seems they treat it as a new contract rather than a change to my existing one which has a year to run and I lose my contraxt discount. Can this be right?
23-04-2020 10:30 AM
@Lockedin2 dont worry, I'm sure one of the Help team will be along shortly to sort this out.
Two things to be aware of :=
1) The amount quoted online does not take into account any discounts you are currently receiving. These will remain after the call plan change.
2) a change in call plan does not start a new contract. However, there is a bug which affects some accounts whereby it does appear to start a new contract. The help team will manually correct this on your account.
23-04-2020 10:36 AM
Thanks for that. Don't know whether to wait or just add it and hope to sort it out when things return to normal. Think I'll go and have coffee and decide later!
23-04-2020 10:51 AM
You've probably got time to decide. Call plan changes dont come into effect until your next billing date anyway...
