Add Caller Display
dcdsmith89
Add Caller Display
Can you please add the Caller Display feature as I am unable to add this via online.
Thank you
4 REPLIES 4
Fixes: 1,587
Re: Add Caller Display
Hi @dcdsmith89 I believe we've now fixed an issue on your account which meant you were unable to add caller display. You should be able to add this normally after 24 hours. Can you let us know how it goes?
Fixes: 1,587
@dcdsmith89 you should be able to add caller display now, can you confirm?
dcdsmith89
Hello,
Yes, I have added the call features again just now and it's awaiting activation.
Thank you
Fixes: 1,587
Thanks for getting back to me @dcdsmith89
Sounds good, it should activate within 24 hours.
Let us know if there's anything else you'd need help with.
