Accidentally cut my telephone line outside my house
bbakker
I was cutting back some bushes, however the external phone line was exposed and I cut it twice, but not severed it. However, I have no phone or internet now. I assume because of this crisis, you are unable to arrange for an Engineer to come out. Are you able to help or do I have to wait until this lockdown is no longer in place? Shame, because I can no longer work from home now. Stupid thing to do, but it is what it is. Can you help? Many thanks, Brian
8 REPLIES 8
Bogbody
Fixes: 4
Re: Accidentally cut my telephone line outside my house
Terminal block
Self amalgamating tape or silicone goo?
Not that I would suggest for one moment that you should fiddle with the BT cable... no no no not at all........
bbakker
lol... we tried insulation tape, but that didn’t work... I think I damaged it too much. Couldn’t have timed it better... lol
Bogbody
Fixes: 4
Someone will need to strip back the cable to fix the cut wires by temporalily connecting them with a terminal block.
Follow the wiiring colours, same colour to same colour.
Then it will need sealing to keep the water out hence self-amalgamating tape or silicone goo.
bbakker
Let me have a closer look at the damage... can’t make it any worse... lol.
bbakker
Cut through at least 2 internal wires in two places... what amp terminal block would it require?
Bogbody
Fixes: 4
A 3A ( 3 amp) or 5A ( 5A ) would be fine.
Any small one really that the wires fit in - nip the screws dont overtighten them, squash and cut the wire. Support the wire so that it cant pull ditectly out of the terminal block.
Its important to water proof the connection or it will soon corrode.
Suggest Screwfix 3A terminal block 25545
Connector junction box
8692H or 54936
Self amalgamating tape 2115V
Use their delivery service 🙂
MatthewWheeler
Fixes: 502
Thanks for getting in touch @bbakker
A large amount of engineering work can be completed outside and often problems can be fixed without an engineer having to enter your property. Where this is not the case, we’ll work with you to get you connected as soon as possible.
Our tests are showing an external issue in this case so we've raised this to our suppliers and we'll update you as soon as we know more
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
bbakker
Thank you for coming back to me on this forum Matthew. You will be pleased to know that we have put in a temporary fix and we are back in the game! I did get it done by someone who had the right tools after a call out on social media and a friend’s husband came out and fixed it for us. However, although the cable now has a box around the join to protect it from the weather, it will probably be better to replace the wire at some point in the future, but that can wait until this thing blows over. Thank you for your support... please keep the ticket open with the external supplier, so that they can come in the future for a permanent fix, but we now have temporary relief and the internet is back on 👍🏻
