2 phone lines in 1
- Home Phone
- 2 phone lines in 1
Re: 2 phone lines in 1
03-12-2014 4:25 PM
In any case, plug a phone in to the test socket inside the master socket (preferably a corded phone) and dial 17070 - check that this reports the correct number. If it does ring your daughters number while the phone is plugged in to the test socket. That might shed light as to what is going on.
03-12-2014 4:44 PM
03-12-2014 4:49 PM
03-12-2014 4:54 PM
03-12-2014 5:00 PM
Also: "sometimes when our number is called it comes up as engaged even though we are not using the phone"
Edit: if an engineer calls to investigate their fault leave your daughters handset off the hook beside a radio/television!
03-12-2014 5:25 PM
03-12-2014 7:14 PM
Maybe she should "play dumb" and answer the phone until the business realise that their line is also connected to another property so they are losing calls. Might prompt them to shout at their own supplier that they have a crossed line and it's losing them business. Might get a quicker response as a business line will probably have a better SLA with OR?
Quote from: dhep1 she cannot answer her phone as it is for next door!
03-12-2014 7:25 PM
I have contacted the ombudsman for this, and hers and my internet, we have good speeds but cannot play games etc. We have to tether to our mobile's!!
If it was not for the fact I paid 1 year in advance for line rental I would cancel the direct debits.
03-12-2014 7:40 PM
The fault will almost certainly be down to sloppy jumpering at the exchange (as that's what has changed) and both parties reporting the same fault, specifying the two numbers that are affected will hopefully prevent wasted engineer appointments etc at the premises (though I wouldn't bank on it!)
03-12-2014 7:50 PM
03-12-2014 8:06 PM
03-12-2014 8:10 PM
03-12-2014 8:23 PM
The fault is incorrect jumpering in the exchange. Plusnet do not have any engineers that work in the exchange - they are not allowed to. All the work in the exchange is done by OpenReach.
03-12-2014 8:26 PM
Surly because the contract is with plusnet they should sort it, quickly.
03-12-2014 8:28 PM
