- Home Phone
- 18185
18185
14-09-2011 3:29 PM
If you're on Homephone evening and weekends with a Plusnet line rental are you able to use to the 18185 override service for daytime calls should you wish?
Message 1 of 3
(2,855 Views)
2 REPLIES 2
Re: 18185
14-09-2011 3:36 PM
Yes you can. What you're referring to is CPS (Carrier Pre-Select) which will work on our services. However, if you have any problems with it, I'm afraid that it's not something that we would be able to support you with.
Message 2 of 3
(327 Views)
Re: 18185
15-09-2011 10:07 AM
I've been using 18185 for about 22 months, in conjunction with Plusnet E&W, and have had no problems
Message 3 of 3
(327 Views)
