- Home Phone
- 1572
1572
13-11-2020 11:36 AM
How do I unblock a blocked number on 1572 that is not on the short list request?
Message 1 of 2
(885 Views)
1 REPLY 1
Re: 1572
16-11-2020 9:30 PM
As far as I’m aware it’s not possible if there’s no option to when you dial 1572.
If that’s the case to remove a number you may have to turn off Call Protect then turn it back on which will effectively reset everything you’ve added to the block list
Message 2 of 2
(755 Views)
