1572 not working although showing as active on my account
Cclack6354
1572 not working
9 REPLIES 9
TheMightyAJ
Fixes: 126
Re: 1572 not working although showing as active on my account
Hi @Cclack6354,
I'm sorry to hear that this is the case. I've reviewed your account and from what I can see, the service should be active. In what way isn't it working? Also, have you tried unplugging your phone and then plugging it back in after about 30 seconds?
 Alex H
Cclack6354
Hi AJ
Thanks for your reply.
I have turned on and off but I still get the message  “The service cannot be connected” when I dial 1572.
Cheers
Chris
TheMightyAJ
Fixes: 126
Hi @Cclack6354,
I'm sorry to hear that this is the case. I'm going to try removing the feature from your account and re-adding it to see if this has any affect. I've removed it this evening and will need to add it back on tomorrow, at which point it should go live within 24 working hours. If it's still not working by the end of Monday, please get back in touch and we'll be happy to investigate further.
 Alex H
peterwallison
My mother-in-law is having the same problem trying to block a specific number.
On dialling 1572 she also gets the message 'the service cannot be connected'.
When she logs in to her account the call features show 'awaiting activation'.
adam945
Fixes: 113
Hi @Cclack6354 - Are the issues surrounding your 1572 service resolved?
@peterwallison if you'd like to send me a PM with the account username, I'd be more than happy to have a look into what's going on here.
 Adam
 Plusnet Help Team - Leeds
Cclack6354
Hi Adam
Just tried 1572 and all working perfect 👍
many thanks for your help in getting this resolved
Cheers
Chris
adam945
Fixes: 113
Hi @Cclack6354
Great stuff! Smiley I'm glad @TheMightyAJ was able to sort this out for you!
 Adam
peterwallison
How do I send you a PM?
TheMightyAJ
Fixes: 126
Hi @peterwallison,
I'm sorry to hear that you're also affected by this issue. If you click on our usernames, you'll see an option on the right hand side of the profile page to send us a private message. Smiley
 Alex H
