1571 seems to be ON even though it's not ticked in my admin
Annie
The 1571 service seems to be ON even though it's not ticked in my admin and I don't want it. How can I turn it off as it's already OFF if you see what I mean?
Annie
9 REPLIES 9
MatthewWheeler
Fixes: 479
Re: 1571 seems to be ON even though it's not ticked in my admin
I'm getting that removed for you now.
[edit]
That should be gone in the next 30 minutes.
 Matthew Wheeler
Annie
Thanks but why was it ON when it wasn't ticked? How long do I need to wait before it takes effect?
Annie
MatthewWheeler
Fixes: 479
I'm not sure in all honesty but it should be gone in the next 30 minutes.
 Matthew Wheeler
waterside49
Same here; have been with Plusnet for years, but have recently moved and 1571 has been activated even though I didn't ask for it.  Can it be removed please as it's messing with my answer machine?  I have elderly clients who are completely confused by it!
Thanks in advance.
Chris
Legend
Fixes: 169
That should be removed in the next 30 minutes or so.
veloman
I've just found that I too have voicemail activated on my line even though I didn't ask for it and don't want it. Only found out because I accidentally knocked phone off and found I had interrupted dial tone. So presumably someone has left a message. I've been trying to find out if I will be charged if I dial 1571 to check any message left but can't find the answer.  Can anyone enlighten me on this?  In the meantime I have found how to switch it off although it might take up to 3 days.
Mav
Fixes: 515
@veloman
1571 is free to dial to listen to your messages.
Forum Moderator and Customer
veloman
Thanks for that information Mav.
MDC3004
I've just noticed that 1571 appears to have been activated on my phone. May I also have it removed?
