1571 nasty surprise not free at PN towers - updated it Is Free
- Home Phone
- Re: 1571 nasty surprise not free at PN towers
16-05-2012 6:52 PM
16-05-2012 6:57 PM
16-05-2012 6:59 PM
However, I thought I recently saw some info that say the basic 1571 as supplied by PN would now allow you to record your own message.
Edit: This is where I read it
Personally I hate 1571, when you phone someone that has it and they are on the phone, you lose the option to use ring back, and it's not always appropriate to leave a message, and if the call isn't within inclusive minutes it's just cost you 20 or 21p or so depending on the provider. Really great that, 20p to get an engaged number
16-05-2012 7:25 PM
16-05-2012 7:29 PM
Can you let us know what lead you to believe that is was not free with your service if selected?
We'll do our best to get whatever message corrected, as we can confirm it is free if you require it and I can see you have selected to have it activated on your account.
17-05-2012 11:03 AM
I'll go with tired for now but if not I viewed it with Opera 11.64
17-05-2012 7:28 PM
Quote from: BryanP If you are on any time it is free
Not true.
I am on Anytime Plus with BT and all 1571 calls are charged at 17p.
In order to get 1571 free, You have to make 6 calls within every 3 months using chargeable BT.
To do this You have to dial 1280 before 01,02,03 calls to qualify the 6 chargeable BT calls
I don't get many messages left me, so I don't bother .
Incidentally, 1471 calls are charged at 17p each also....
18-05-2012 8:51 PM
Quote from: Gus When I checked it yesterday morning, the only option was the £3 Extra option to enable voicemail. But I had a look again later that night and either I was tired or a glitch when I looked in the morning as the free option wasn't listed then.
I would suspect that this means you already have the free version of 1571 enabled on your phone line. Calling 1571 is free, so I would suggest calling it and seeing if it will direct you to a mailbox or not?
We do offer two types of Voicemail service, the free version is normally added to most accounts as standard, this can be removed at any time, this offers just the basic mailbox. The Voicemail Plus, which is charged at £3 has additional features, such as a larger mailbox and the facility to change the number of rings before diverting to the mailbox and the option to record your own personal greeting.
Let us know if you don't have the free 1571 service on your line as this should show in the member centre for you to add.
18-05-2012 8:57 PM
Not correct - you can record your own message on standard voice mail
Quote from: scream We do offer two types of Voicemail service, the free version is normally added to most accounts as standard, this can be removed at any time, this offers just the basic mailbox. The Voicemail Plus, which is charged at £3 has additional features, such as a larger mailbox and the facility to change the number of rings before diverting to the mailbox and the option to record your own personal greeting.
http://www.plus.net/support/phone/call_features.shtml#voicemail
Re: 1571 nasty surprise not free at PN towers - updated it Is Free
18-05-2012 10:40 PM
01-06-2012 6:41 PM
Quote from: community
Free
No 1280 required
Free
03-06-2012 7:32 PM
03-06-2012 8:34 PM
03-06-2012 10:26 PM
04-06-2012 2:32 AM
- Home Phone
