1571 Voicemail removal
- Home Phone
- 1571 Voicemail removal
3 weeks ago
Hello
can you please remove the 1571 voicemail option from my account . This option is not available via the control panel for call features
thanks
1 REPLY 1
Re: 1571 Voicemail removal
3 weeks ago
@EileenT1932 Welcome to the forum. 🙂
There's an ongoing problem with the call features page which means that you can't scroll down to see some of the available features.
Depending on your screen size and resolution, you may be able to see and tick the box if you zoom out with your browser.
Otherwise, one of the PN guys will pick this up and do the necessary.
The older I get, the earlier it gets late.
ADSL2+ Billion 8800NL
