1571 Voicemail removal
- Home Phone
- Re: 1571 Voicemail removal
01-01-2021 2:14 PM
Hello
can you please remove the 1571 voicemail option from my account . This option is not available via the control panel for call features
thanks
Message 1 of 2
(379 Views)
1 REPLY 1
01-01-2021 2:51 PM
@EileenT1932 Welcome to the forum. 🙂
There's an ongoing problem with the call features page which means that you can't scroll down to see some of the available features.
Depending on your screen size and resolution, you may be able to see and tick the box if you zoom out with your browser.
Otherwise, one of the PN guys will pick this up and do the necessary.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 2
(361 Views)
