1571 Voicemail - please switch off!
RickDownton
Hi - I've been trying to deactivate the 1571 voicemail as it is clashing with my own answerphone - but the website control panel won't allow it, there is no 1571 option to turn it off, there is at least a 30 min holding time for phone contact, no online contact ....  do I have any other options? From searching this forum it is obvious I am not alone ....
9 REPLIES 9
MattyC
Fixes: 46
Re: 1571 Voicemail - please switch off!
Hi there Rick,
I suppose it shouldn't have been provisioned on your line in the first place, so really sorry for this. I have placed an order to have it removed - are you ok to check your line at 4pm today (or later)?
Matty
RickDownton
Hi MattyC - yes, certainly will!
MatthewWheeler
Fixes: 479
The order to remove it has completed so it should be gone.
 Matthew Wheeler
RickDownton
Hi Matthew - yes it's gone!
Many thanks for your prompt work.
MatthewWheeler
Fixes: 479
No problem at all  Smiley
 Matthew Wheeler
gcs
Me too! Would someone please deactivate my 1571 Voicemail?
MatthewWheeler
Fixes: 479
@gcs
I've placed the order to remove 1571 for you.
It should complete within the next hour or so.
 Matthew Wheeler
gcs
Much appreciated. Many thanks.
frankebsworth1
I have also aquired 1571 and did not ask for it or need it. Please can i have it removed
