1571 Voicemail called me
Pete101
I have call forwarding active. I received a call from my home phone to update me on my voicemail. I've never had that happen before and can't find it listed as a function  before. Is it a standard feature ? I don't want to pay for unnecessary calls.
6 REPLIES 6
198kHz
Fixes: 40
Re: 1571 Voicemail called me
AFAIK Voicemail Extra will call to tell you there's a message if it arrived while your line was engaged. Voicemail free will not.
Can't see that call forwarding would make any difference.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Pete101
It could well be that. These days it's mainly the automated spam calls I hadn't already blocked that trigger 1571 !
Pete101
Just double checked, I dont have Voicemail Extra, just the free one.
198kHz
Fixes: 40
In that case I'm stumped - unless the free version has changed.
seebee
Fixes: 9
Free voicemail will call you if someone has sent an SMS text message to your landline number. It'll say you have a "voice text" and if you listen to it, the system will read out the contents of the text. Could that be it?
I've had it happen by accident - when someone has chosen my landline number instead of my mobile number when composing an SMS text to me.
Pete101
I've just sent my home number a Text. Got an immediate response and call, but not from my landline number. I could listen to the Text and delete it. I also received a Text reply from my landline. Nothing in the Text however.
When I got the original 1571 call, it came up on my mobile as a call from the Home Landline. Todays was a 0333 number.
