1571 Active and can't be disabled
Joan55
The 1571 feature is active on my phone line (even though I did not request it) and I am unable to disable it through my account as the voicemail calling feature is not selected. Is there some way this feature can be disabled either by myself or by Plusnet?
3 REPLIES 3
dhart95
Re: 1571 Active and can't be disabled
I have the same issue, not selected on the call features page, but is active on my line.
MatthewWheeler
Fixes: 478
Thanks for your post @Joan55 and @dhart95
I've manually removed 1571 off our supplier's systems for you
If there's anything else we can help with let us know
 Matthew Wheeler
Vanessa5
Hi
I am having the same problem. Please could you disable 1571 on my account too?
