- Home Phone
- 1471
1471
26-12-2013 8:47 PM
I have found out the hard way that with PN you get billed 15p for using 1471. What other services which 1****** services to PN bill you for.
Feels a bit like cheap line rentals but watch out for the extras.
![Cry Cry](/html/@6B4B63041062049E874E6843927E9ADE/images/emoticons/cry.gif)
Message 1 of 6
(1,502 Views)
5 REPLIES 5
Re: 1471
26-12-2013 9:01 PM
1471 is free to use. It is when you use the callback option that it charges the 15p.
If you have a look across other phone operators it is a fairly standard charge (BT 17.7p, Talk Talk 20p, Sky 17.7p)
Message 2 of 6
(805 Views)
Re: 1471
26-12-2013 9:15 PM
In that case i am being missed charged as I have not made any call backs that I am aware of. While we are at it my call charges although not great are 97p in discrepancy. May be i will have to challenge these fees then. thanks for the info.
Long shot but as I am still having phone line noise issues is it possible that noise could be causing adhoc calls. Incoming call s in particular drop my broad band.
Message 3 of 6
(805 Views)
Re: 1471
26-12-2013 9:23 PM
So when you've dialled 1471 and it's said "Number xxxxxxx called you today at 10:30am please press 3 to call back", you've never pressed the number to dial that number back ?
I use 1471 on my Plusnet line a few times a day and have never been charged for it. I don't use the dialback function though.
Message 4 of 6
(805 Views)
Re: 1471
26-12-2013 9:29 PM
Picbits yes that is correct. I did use 1471 to check the issues I have with phone class dropping my broad band and noise. I have never pressed 3 to call back or phoned a number and set up ring back. My call charges and call log differ by 97p not including the 15p for a call back????
![Huh Huh](/html/@E2297E1574AC8AB2FE5882A8865382BF/images/emoticons/huh.gif)
Message 5 of 6
(805 Views)
Re: 1471
26-12-2013 9:38 PM
Hmm strange - hopefully one of the DCT will be on to pick this up in the morning.
I got charged for doing the callback on the 1471 many many years ago and have never used it again after finding out it charged for the callback.
There is also a charge when you call an engaged number and it asks you if you want a callback when their line is free.
Message 6 of 6
(805 Views)
