1471 problem
- Home Phone
- Re: 1471 problem
1471 problem
29-05-2008 11:00 AM
Hi,im trying to figure out,how can i get rid of the last number and the intermittent tone before you ring 1471.All i get at the end is---to return the call press 3 there is a charge,etc.etc.
regards ray.
Message 1 of 5
(2,559 Views)
4 REPLIES 4
Re: 1471 problem
29-05-2008 11:53 AM
If you've got an intermittent tone it sounds as if you've got voicemail! Have you tried dialling 1571? You'd then need to listen to the message and press 3 to erase it.
To clear the last number out of 1471 you need to dial 1475 and hang up. You're phone will ring and the number of the last call will be erased.
As an aside - although it says there's normally a charge to press 3 to return the call, the "charge" for this service with PN is zero!
Message 2 of 5
(602 Views)
Re: 1471 problem
29-05-2008 12:58 PM
Hi Paul03 and thanks a lot mate,was great help,didnt realise there was no charge with pn for return calls,is that all calls where you can redial with the 3 prefix.regards again ray.
Message 3 of 5
(602 Views)
Re: 1471 problem
29-05-2008 1:04 PM
There's no charge for pressing "3" (IIRC BT charge 7.5p) but you still pay the package cost of your call (which would only be zero if it was an inclusive 01/02/03 call).
Edit: typo
Edit: typo
Message 4 of 5
(602 Views)
Re: 1471 problem
29-05-2008 1:07 PM
Thanks again and understood.regards ray.
Message 5 of 5
(602 Views)
