1471 press 3
- Home Phone
- Re: 1471 press 3
1471 press 3
19-03-2009 10:46 AM
Just joined Home Phone Anytime+ this is my first day.When you have used 1471,to find the last call if you then press 3 to contact the last caller is that free as it seems from the tariff list,I seem to remember that under BT there was a charge I stopped using it but it is a very useful feature.TED.
Message 1 of 3
(1,304 Views)
2 REPLIES 2
Re: 1471 press 3
19-03-2009 3:32 PM
The ringback is free although you have to pay for the call if it doesn't come under your included calls package.
Bob
Bob
Message 2 of 3
(318 Views)
Re: 1471 press 3
19-03-2009 5:25 PM
Thanks Bob I found it very useful as you don't have to go through the address book to find the number again as I used to do when it was chargeable.
Message 3 of 3
(318 Views)
