1471 call return
- Home Phone
- 1471 call return
1471 call return
07-01-2014 7:51 AM
acording to my home phone control panel 1471 return is Free
i am on the anytime call plan
Re: 1471 call return
07-01-2014 8:22 AM
07-01-2014 8:44 AM
07-01-2014 8:49 AM
07-01-2014 10:46 AM
07-01-2014 11:21 AM
The OP's query was about call return when using 1471.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
07-01-2014 12:16 PM
07-01-2014 1:58 PM
07-01-2014 4:34 PM
no where does it state its free unless you use it
07-01-2014 4:39 PM
07-01-2014 7:08 PM
Quote from: rongtw no where does it state its free unless you use it then charge is 15p
to use it
surely the word FREE is misleading
Just to clarify -
Dial 1471 to check last number that called - free.
Press 3 to call that number - 15p surcharge on top of normal call rate.
08-01-2014 11:40 AM
i know there is a charge but just by reading you would say it is misleading , it may just need clarifing on the page
08-01-2014 11:41 AM
08-01-2014 11:48 AM
08-01-2014 1:21 PM
1471 call return is not 'a feature' IMO, it's part of the 1471 feature so should not be listed as a free feature, at the very least it should have a '*' with a note explaining it costs 15p to use the 'free feature'.
