1471 call return
rongtw
Fixes: 12
1471 call return
A quick question , 1471 call return , free or 15p to use .
acording to my home phone control panel 1471 return is Free  Wink but on every bill i recive i am charged 15p each time  Crazy
i am on the anytime call plan
24 REPLIES 24
Fixes: 395
Re: 1471 call return
According to the Home Phone tariff here http://www.plus.net/home-broadband/tariffs/ 1471 is free BUT 1471 Call Return is 15p/call
Mayfly
All Star
Yes if you dial 1471 then press 3 to ring them back the ring back part is chargeable.
James
The presence of the feature itself is free (ie: you don't have to pay to add it), but the use of it is chargeable as outlined above.
jelv
Fixes: 10
If you use it a lot you can add Ring back for £2.50 per month when there is no charge for the ring backs (you'd need to use it more than 17 times a month on average).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
198kHz
Fixes: 41
True, jelv, but that's for using ringback if the called number is engaged.
The OP's query was about call return when using 1471.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
HaresEar
I have raised a ticket and had a refund for one call to 1471. I have used 1471 but never used the call back feature.  I have had further charges for using a free service.  I have asked for further investigation.  If possible can it be proved I used the call back feature by pressing 3?  There are no corresponding calls on my itemised bill to indicate the call back was used although if the called number did not answer this would not show.
BenTrimble
If the call you returned isn't answered (and doesn't go to voicemail, etc.) then there would be no matching call after the ring back event. Calls are confirmed to be made by your line unless something else indicates otherwise e.g. overlapping durations, fault was open, etc. etc.
rongtw
Fixes: 12
Cheers for the Replies , but if you look a the capture it States " 1471 call return " is FREE !!
no where does it state its free unless you use it  Angry then charge is 15p  Crazy to use it Huh surely the word FREE is misleading
James
198kHz
Fixes: 41
Quote from: rongtw
Just to clarify -
Dial 1471 to check last number that called - free.
Press 3 to call that number - 15p surcharge on top of normal call rate.
rongtw
Fixes: 12
I am not complaining about the charge , the point i am trying to make is , on my capture if you read it actually says "1471 call return = free"
i know there is a charge but just by reading you would say it is misleading , it may just need clarifing on the page  Wink
James
I appreciate the point that you are making, but I have stated twice in this thread that having the feature is free, but it costs to use it.
Strat
Fixes: 565
Or to be more accurate 1471 is free  1471 Call Return is chargeable.
w23
Fixes: 4
Which is precisely the OP's point!
1471 call return is not 'a feature' IMO, it's part of the 1471 feature so should not be listed as a free feature, at the very least it should have a '*' with a note explaining it costs 15p to use the 'free feature'.
Call me 'w23'
