0871 and 0844 calls .....how much do they cost?
- Home Phone
- 0871 and 0844 calls .....how much do they cost?
03-10-2009 8:50 AM
Re: 0871 and 0844 calls .....how much do they cost?
03-10-2009 9:57 AM
03-10-2009 9:58 AM
You will see that the charges aren't all the same for 0871 and 0844 - you need to check the next 3 digits
03-10-2009 10:10 AM
04-10-2009 5:58 PM
10-10-2009 11:00 AM
21-10-2009 11:41 AM
A comment too about the calculator idea would be good as it appears many firms are now moving to 0844 where they used to use 0845
Interesting how staff here respond so quickly sometimes and sometimes not at all. In essence this would seem a simple thread for a reply.
.........................proud" say Pnet.
21-10-2009 11:44 AM
I'll ask Mand what the actual charges are and get back to you once I have an answer.
29-10-2009 10:21 AM
29-10-2009 10:26 AM
There's no actual answer because the prices themselves vary so much depending on what the fifth number is on the telephone number.
http://www.plus.net/residential/tariffs/homephone.html
You'll need to find out the code of the call and the prices are shown in the Specialised Number Call Tariff section.
29-10-2009 10:39 AM
Quote from: Jameseh You'll need to find out the code of the call and the prices are shown in the Specialised Number Call Tariff section.
You'll get the code of the call from here under the column marked "charge rate".
- Home Phone
