0870 rates
fotobits
0870 rates
Are 0870 rates now the same as 01/02 numbers?
If so, are they to be included in the free evening and week-end allowance?
Regards
4 REPLIES 4
pierre_pierre
Re: 0870 rates
According to OFCOM, who have made a balls up of the Broadband issue, they should be from 1st Aug be treated as normal national calls
no the only included ones are 01/02/03 and 0845 to PN, plus of course 0800 and 0500
fotobits
Re: 0870 rates
Many thanks, pierre_pierre, so 0845 is now the same rate as 01/02 and is included in any free allowance?
Great!
Most grateful......
pierre_pierre
Re: 0870 rates
read my reply carefuly, 0845 is not included only those to PN
fotobits
Re: 0870 rates
Sorry, pierre_pierre, yep calls to +Net Support are the only free ones.
Cheers
