0844 numbers
MaestroMan
0844 numbers
I'm currently on the free three-month trial of Talk Anytime time.  I know 0845 and 0870 calls are included but what about 0844?  A charge of 69p has come up for one I made recently. Sad
10 REPLIES 10
pierre_pierre
Re: 0844 numbers
sorry, only 845 and 870  - 844 and 871 are paid
MaestroMan
Re: 0844 numbers
I thought that might be the case.  But it ought to be clearly stated in the Home Phone Tariff, which only mentions 0845 and 0870.  What about the other codes?  BT used to have quite a long list, showing how much each one cost.  PN implies all Local and National (+ 0845 and 0870) are included - when obviously they're not!
pierre_pierre
Re: 0844 numbers
Oh yes they are  01,02,03, are the local andf national numbers 0845 ans 0870 are special numbers.
there are also free phone numbers 0500 and 0800
a full list is here, http://www.plus.net/residential/tariffs/homephone.html but takes a bit of reading
Specialised Number Call Tariff
Specialised numbers are defined as calls to non geographic numbers such as Premium Rate services, Directory Enquiries and calls to Internet Services. Calls of this type are charged in one of four ways:
  1. Calls that are charged by the length of time you are on the phone. The pence per minute price also varies according to the time of day (eg 070056).
  2. Calls that are charged by the length of time you are on the phone but where the rate you pay does not vary by the time of day (eg 0871550).
  3. Calls that attract a one-off fee, and a pence per minute price which varies according to the time of day (eg 090117).
  4. Calls that attract a one-off fee irrespective of the length of time that you are on the phone. The charge may or may not vary according to the time of day.
All call charges are pence per minute and include VAT.
reserved
Re: 0844 numbers
And you may have to look at this as well  Huh
MaestroMan
Re: 0844 numbers
Thanks for all that.  It seems that not every 0844 number costs the same, so I'll try to avoid them!
reserved
Re: 0844 numbers
You may be able to find alternative geographic numbers here
coastergrotto
Re: 0844 numbers
Whoever came up with the complex pricing system for the 0844 numbers should be put in front of a firing squad IMHO.
198kHz
Fixes: 41
Re: 0844 numbers
+1
If a firm uses 0844 they don't get my custom.  Angry
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
pierre_pierre
Re: 0844 numbers
My Local NHS - Broomfield, Chelmsford does.  And before any one say  use saynoto0870  they dont work now
danger11
Re: 0844 numbers
I find it bad that a company purely uses a 0844/0871 number, they use it only for Revenue gain, 0845 are just as bad. Which is why i use saynoto0870 (It even has plus.net numbers in there)
