0844 charges ?
Ashtonio
0844 charges ?
Hi everyone.
I'm looking to switch my home phone (evenings & weekend package) service to Plusnet.
I use an 0844 number quite a lot & with BT which works out around 3p a minute.
However, I can't find out how much Plusnet charge for these call types. I've trawled through all the tariff listings on the website & even phoned the Plusnet  helpcentre who couldn't give me a definite answer !
Please can anyone help ?
Much appreciated.
7 REPLIES 7
pierre_pierre
Re: 0844 charges ?
Welcome to the forum
why dont your use http://www.saynoto0870.com and get a number which is free
As for the rest of the Query  it is a mad table to negotiate, I think only Mand on the staff understands it
Oldjim
Fixes: 63
Re: 0844 charges ?
You need to look here
http://www.productsandservices.bt.com/consumer/consumerProducts/pdf/SpecialisedNos.pdf
note down the "Type of Call" example 0844 688 is g24
Look here
http://www.plus.net/residential/tariffs/homephone.html
and you find that g24 is 5p per minute
pierre_pierre
Re: 0844 charges ?
blow me only three and a bit pages of the 0844 etc numbers to remember, better bookmark those links
Be3G
Re: 0844 charges ?
Quote from: Oldjim
Look here
Note that there is also a 9.3p call set-up fee, mentioned at the very bottom of the table.
pierre_pierre
Re: 0844 charges ?
Sorry not that simple as different 0844 asdfg hve different codes, you have o look through the 4 PDF pages to find the code, any one of
FF29, g2, g4, g6, g7, g, g9, g10, g11, g14,g16, g17, g19, g20, g22,g24,g27,g2, i1, i3, i5, i8, i13, i14, i15, i16, i17, i18, i19, i20, i21,i22, i3, i24, i25, i26, i30 - then  look up the PN liist - they all havea  different cost
Sorry if I missed any of the codes, I am in a  hotel room 245 miles from this morning
Be3G
Re: 0844 charges ?
If you're responding to Jim there, note that he did say the 0844 688, g24 number was just an example. If you're responding to me about the call set-up fee, then the code doesn't make any difference – all chargeable calls appear to attract the same 9.3p fee.
Ashtonio
Re: 0844 charges ?
Thanks very much for all your help guys & taking the time to provide very helpful info. so quickly I was seriously questioning my sanity after looking at that lovely table for god knows how long. I should be able to work it all out now.
All the best.
