0844 call charges
Rob52
0844 call charges
Can you tell me the charge for calls to 0844 numbers on a Talk Anytime monthly contract please?
10 REPLIES 10
James
Re: 0844 call charges
They vary depending on the numbers after 0844.
This link should tell you what the call banding is, which you can match against our tariff
http://www.productsandservices.bt.com/consumer/assets/downloads/BT_PhoneTariff_SpecialNos.pdf
http://www.plus.net/residential/tariffs/homephone.html
Strat
Fixes: 565
Welcome to the forum Rob52 Smiley
glloyd
Call charge are now so ridiculously complicated it takes a lawyer and accountant to work out what you pay for what. There has to be a simpler way of working out charges without having to consult pages of figures before you make a call.
reserved
Always worth a look here to see if there is an alternative free or cheaper number.
finrod
Okay I'm interested in 0844 870 7894 - which is a g6  5 - but I'm still none the wiser.
There ought to be legislation to indicate tariffs up front, even if they are approximate.
James
G6 is 5.11ppm
MavisX
Could I hi-jack Rob's thread for a moment and ask what price per min
does g8 attract having waded through the info provided by the link and
being unable to make any sense out of it?
Thanking you in anticipation.
orbrey
I believe at present it's 2p per minute.
James
You should be able to find all of the codes on here:
http://www.plus.net/home-broadband/tariffs/
MavisX
Many thanks.
