0800 numbers in Itemised Bill
adagio
I made a 0800 call to nPower  in late September early October. I am trying to find a record of the call but the itemised bill does not list it. Should I expect it to?
13 REPLIES 13
Oldjim
Resting Legend
Fixes: 63
Re: 0800 numbers in Itemised Bill
from other posts - they aren't reported to Plusnet by the BTw systems (I think I have got that right) so they don't show up on the bill
orbrey
That's correct I'm afraid - we only get the data for calls we're charged for, and as that isn't the case with 0800 numbers we don't get the information. There's also the fact that a lot of 0800 numbers are calls that people may want to keep confidential (childline etc) so I'm not sure we could get that information either I'm afraid.
BenTrimble
Anotherone
Champion
Fixes: 21
If adagio provides the full 0800 number and the approximate date, PN should be able to confirm the time and date the call was made.
Chris
Legend
Fixes: 169
How? We don't get 0800 call data so can't trace it back.
Anotherone
Champion
Fixes: 21
You have to ask BTw  Wink
orbrey
Quote from: Matt
Anotherone
Champion
Fixes: 21
It is not a Childline or other confidential number. You have been told quite clearly what the number was which you can obviously check. If someone is having a problem with an electricity supplier and need to prove they made a call, they should not need to get a court order just for you to retrieve that very specific information.
Before BTw stopped passing that information to you, I had no trouble on one occasion getting confirmation of one call from yourselves and some considerable time back nor did I with another supplier on a different matter.
BenTrimble
I'll put the question to BTW Billing to see what the process would be, if we did need to confirm if an 0800 call had been made, might be a little while before I get an answer though Smiley
Anotherone
Champion
Fixes: 21
Well done Ben, time delay comes as no surprise  Wink
BenTrimble
BTW Billing have confirmed that this information is not available to themselves, either. They have offered routes to escalate the query so it's possible that we might be able to track down a call under certain scenarios.
BRABUS
Turn it around on nPower and get them to prove you didn't call them?
Razer
You can't prove a negative.
