0800 and other free calls
Teds31
If as stated only 01, 02 and 03 calls are free on anytime+ ,what happens with 0800 and other free calls.I didnt see them mentioned in the charges list,only 0845 etc.
19 REPLIES 19
Mand
Re: 0800 and other free calls
0800 calls will still be free, as will 0808 and such. Those calls are free on all packages regardless of your inclusive calls.
Teds31
Thanks Mand glad thats cleared up.TED
pierre_pierre
what on earth were you dialing and from where to get that message?, I have no trouble with 0800 nos from Essex
nadger
Code for UK is 44 so he dialing where ever 49 is Smiley
Looks like Germany
pierre_pierre
no and you didnt say you were on voip, you are using the home phone forum
fred
sorry to have troubled you
pierre_pierre
I am not sure but on a Bt type line, if you phone from abroad the 44800 does not work, many companies also give out a 44 ----- number as well and yes the suffix 49 is Germany
nadger
That fact is often a useful way of finding a local number for a company that gives out 0870 UK numbers  Wink
pierre_pierre
miserable bloke, he's deleted his query and movedd to voip
Quote from: pierre_pierre
Prefix presumably?
pierre_pierre
Dont be picky I was slightly annoyed
LiamM
I thought this thread was bloomin confusing!!
pierre_pierre
Didnt you say something like that in another thread today, Its all those worms you live with now  Cheesy
Murray
This seems as good a thread as any to ask....
I'm a new customer and I'm just wondering about the 'free' call length of 60 minutes; if I hang up before 60 minutes and then recall the same (eligible) number for another period of less than 60 minutes, it's not going to cost me anything is it?
I'm sure this has been answered multiple times but I'm not having much luck with searching!
Thanks in advance
