youve seen Street art, this is the wall
- General Chat
- youve seen Street art, this is the wall
02-03-2010 11:45 AM
Artist John Pugh
3D murals painted on the sides of buildings by
Trompe L'oeil (trick-of-the-eye) artist John Pugh
Re: youve seen Street art, this is the wall
02-03-2010 11:58 AM
02-03-2010 1:14 PM
02-03-2010 1:15 PM
Customer and Forum Moderator.
02-03-2010 2:08 PM
Quote from: Midnight Sorry but to me they all look what they are fake just paintings.
Gary, is this a function of Dyslexia?, my wife has a problem with the central vision on one eye, not macula degeneration, but similar effect, she said the same as you
02-03-2010 2:26 PM
http://static.panoramio.com/photos/original/23830300.jpg
02-03-2010 2:42 PM
02-03-2010 3:55 PM
02-03-2010 3:57 PM
02-03-2010 3:58 PM
Quote from: pierre_pierre Gary, is this a function of Dyslexia?, my wife has a problem with the central vision on one eye, not macula degeneration, but similar effect, she said the same as you
Hi pierre I don't know if it is a function of Dyslexia or not, but I will tell you how I know that thay are just paintings, I will go one by one:
Top painting #1
#1 wen you look at it in full screen you can see straight off that it is a painting, but a very good one the woman and the internal walls give it a way.
#2 wen you look at it in full screen you can see straight off that it is a painting, but a good one the columns give it a way.
#3 wen you look at it, it looks like a computer generated painting.
#4 wen you look at it you can tell it is a very good painting why because wen you look at the brics thay look wrong and so is the womans skin colour plus her hair looks wrong.
#5 wen you look at it, it just looks fake.
#6 it looks like a computer generated painting to me.
#7 it looks like a computer generated painting to me.
