would you trust a Mature Woman?
Re: would you trust a Mature Woman?
Very good
Pierre, it wasn't working with Adobe Reader but is OK after Oldjim replaced your link.
but did my latest work, As Jim said I had used Foxit, the second was the Open Office, export to PDF, dont know what Jim used
Pierre your second attempt worked with Adobe V9
Fixes: 62
I opened it in PDF-XChange Viewer then printed it  as a PDF using Cutepdf which got rid of the Foxit illegal (Adobe version) formatting
I always use the cutepdf driver for PDFs.
Fixes: 62
This is one of the problems with Foxit - although it is supposed to be fixed in the latest version but doesn't seem to be
http://forums.foxitsoftware.com/showthread.php?t=9849&highlight=adobe&page=2
Anyway, it is now readable but it has been round as an email several times in the few years I have had internet access!
What do the other applications have over Adobe Reader?
no payload
Fixes: 62
Let me put it this way.
With PDF-Xchange Viewer the total file size is only 17.6MB and it doesn't get its claws into everything like Adobe
There are a lot of extra things which you can do such as add text to a PDF document and save the results - so you can fill in forms and save them
You can annotate documents including highlighting text
As an example I have messed about with Pierre's original here
One other thing it is much much faster
Thanks Oldjim for the details, I'll have a look at PDF-Xchange Viewer.
Pierre - don't understand your post.  Are you suggesting Adobe reader is chargeable, it's free.
Fixes: 62
He meant that it sticks a load of unnecessary stuff all over your PC - file size 33.5MB - so what is all the extra used for as PDF-XChange Viewer is 17.6MB and does far more
^ Not to mention it takes an eternity to start, is forever wanting to connect to the web (never did find out how to switch that off :-\) and if the Adobe site is down or undergoing maintenance, it hangs your browser. Angry
Have swapped it for foxit and it does seem to be better.
