wma conversion
stanb
wma conversion
I want to convert some audio files from wma to mp3 format. Can anybody recommend a reliable conversion package which I can download from the internet?
Thanks for any possible suggestions.
Lurker
Re: wma conversion
Do you have many?
www.media-convert.com is a reliable online service if you have just a couple.
If you have a larger library, its worth downloading something to do it.
I'll try and find the name of the tool I used for converting my library (but be warned, if you have thousands, it will take some time!)
itsme
Re: wma conversion
Believe it can be done using iTunes.
thejudge
Re: wma conversion
You could try Switch Sound Converter:
http://www.nch.com.au/switch/index.html
stanb
Re: wma conversion
Hi James,
Thanks for your reply. No, I do not have thousands of files - maybe 100 or so.
Fixes: 46
Re: wma conversion
You might want to check out this http://www.nch.com.au/switch/
I've used their voip phone and it was pretty good so maybe their file conversion is too!
Edit: thejudge types faster than me...
stanb
Re: wma conversion
Thanks for the replies. I have tried the Switch Sound Converter, and this has worked well. So, problem solved. Thanks once again.
Stanb
Fixes: 16
Re: wma conversion
Have a look for Quickmediaconverter.....
Try here
http://quick-media-converter.en.softonic.com/
Easy to use, and many formats covered.... including MP3
Oh yes.....it is FREEEEEEEEEEEEEEEEEEEEEEEEEEEEE!
Fixes: 168
Re: wma conversion
Audacity is also rather good (& free) Smiley
Forum Moderator and Customer
