why is
Blim
why is
why is millisecond called millisecond when its not a millionths of a second its a thousandth of a second?
pierre_pierre
Re: why is
for the same reason a millimetre is 1/1000 of a metre
James
Re: why is
It's not a millionth.
milli- 
a combining form meaning “thousand” ( millipede ): in the metric system, used in the names of units equal to one thousandth of the given base unit ( millimeter ).
Origin:
< French  < Latin,  combining form of mille  thousand
Fixes: 18
Re: why is
Erm.... I think this is to do with mille being italiano for 1,000 ? ? ? ?
( think Roman Roads)..... A Kilo metre is not a Heavy Weight Length is it?
itsme
Re: why is
Kilo is Greek.
So a knowledge of Greek and Latin is needed.
James
Re: why is
Quote from: shutter
I think I pointed that out in my quote above - it's from Latin.
Fixes: 18
Re: why is
I was posting at the same time as you.  Roll eyes
198kHz
All Star
Fixes: 10
Re: why is
That's cleared that up then. Just to add, for the OP, a millionth of a second is a microsecond.
Remember you are unique - just like everyone else
itsme
Re: why is
Which is also Greek.
Blim
Re: why is
now I remember why I never took history  Roll eyes
cool, just wonted to get my facts right.
Re: why is
If you have an event in your life that only takes a millisecond to complete perhaps you would let us know the details...keep it clean!!
Fixes: 62
Re: why is
The time between the traffic lights turning green in Mexico City and the first driver honking his horn  Grin
Fixes: 100
Re: why is
I'm sure long suffering SWMBOs will be dragged into this.
Customer and Forum Moderator.
Fixes: 18
Re: why is
Quote from: Oldjim
A friend of mine, gave that, as the definition of........ "the shortest amount of measurable time"  Cheesy
pierre_pierre
Re: why is
the difference in the lap time between the first and second place on the F1 grid
or the timing on the 2 km downhill alpine races
