well do be careful
pierre_pierre
well do be careful
as seen recently
thejudge
Re: well do be careful
I saw a sign containing wise advice a couple of miles from here only the other day:
One of the preceding is very wise, the other is simply how it should be. Any guesses for which is which?
A sat nav is no substitute for brains Cheesy
198kHz
Aspiring Champion
Fixes: 13
But what if you can't read the sign...? Spotted at the local recycling facility.
Remember you are unique - just like everyone else
mentalist3d
lmao  Grin
