virtual router
Blim
virtual router
Whats the difference between over loading a server with too many virtual routers and bandwidth throttling or connection shaping?
WTF
Re: virtual router
I give in: what is the difference?
Fixes: 19
Re: virtual router
Probably the same as the difference between conserve, marmalade and jam  Undecided
Fixes: 20
Re: virtual router
If you overload then ALL traffic will be slowed, whereas with rate limiting etc you can choose what traffic is slowed.
nanotm
Re: virtual router
connection shapeing is a reactive process that allows higher priority data wider bandwidth whilst load sharing (slowing) the transfer rate of lower priority stuff, throttling is a fixed limitation that slows down all designated traffic (with in the defined rules)  and overloading will most likely cease all correct performance, but certainly at the very least will cause everything to travel at snails pace..
