usage hammered
scootie
usage hammered
been at me mums since monday night and all ready starting to see the diffrence in the amount my family use, kids havent even unwrapped the xbox yet, tho i have had to win update 2 vista laptops with 60 odd critical updates, havent even used any HD sources either.
got to say the updates didnt seem to be speed capped like when unlimited, hopefully the xbox updates are just as smooth on xmas morning
so if your net is on a go slow its my kids  Lips are sealed
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: usage hammered
Hi Asbo Dog,
I'm not sure you have anything to worry about with those statistics. For example take a look at the usage that I seem to have racked up on the image below. The use of the Xbox uses a surprisingly small amount of usage when you compare it with things such as streaming in HD.
Chris Pettitt
Cloud Environments Engineer
