text
text
Ahem!!, not being conversant with the nuances and complexities of text speak. Someone has just sent me a message prefixed with : sox
Ok I understand I'm not "with it" <decidedly without it actually> but could someone tell me what sox interprets as please?
The sender is hardly in the first flush of youth, but obviously more up to date than I am. I suppose I could ask the sender but pride prevents me....
Innit
Fixes: 247
Re: text
the only context (outside baseball) that I know of is as a replacement for 'socks'
never seen it used for anything else..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Roberto0151
Re: text
Lots of possibilities on this site:  http://www.acronymfinder.com/ .But I doubt they will help Smiley
Re: text
Would 'sorry' fit?
Soz is usual text speak, but on smart phone, auto correct selects Sox.
I'm often guilty of not checking before sending! Smiley
Re: text
Thank You DB, that's the closest to an answer I've had. The message actually was on Skype from somebody who hasn't replied to me for some time (very busy, as uses Skype for work)
But that could well be it.
Fixes: 131
Re: text
Some options here http://www.urbandictionary.com/define.php?term=sox.
The Urban Dictionary is a good source of informations about the more obscure.
Customer and Forum Moderator.
Re: text
Option 2 not very likely in this case Shocked
RichAllen
Re: text
A certain local forum I used to post on doesn't allow text speak, because according to the Mods, they have users who use machine readers to read the forum, which can't decipher text speak.
They tend to get rather upset if people use it, closing threads and banning the poster.
Re: text
Don't we have a ban on text speak as well Undecided
Fixes: 131
Re: text
http://community.plus.net/forum/index.php/topic,218.0.html#post_rubbish would cover it.
