stopmotion animation software
bluewhale
currently unemployed and so trying to keep busy
so been developing a stop motion animation application for use with webcams etc
anyone want to have a go...windows only i'm afraid
you can download here and comment ( positive i hope )
http://ccgi.bluewhale.plus.com/
6 REPLIES 6
Fixes: 112
Re: stopmotion animation software
Looks like fun, I'll give this a go at the weekend if I have some spare time Smiley
 Adam Walker
Fixes: 382
I get the error attached below when I start it on W7 64bit but it seems to run after that.
Now all I have to do is find out how it works Embarrassed
Customer and Forum Moderator. Windows 10 Firefox 72.0.2 (64-bit)
Life is tough enough without adding Linux into the mix.
bluewhale
if you could do me a favour...
you'll find the log files in %TMP% directory
they'll be SharpAnimator.txt, .1 , .2 etc
if you could either post them on here or on the other site that would be great
never tried on 64bit OS...
bluewhale
Quote from: Strat
had a go on a 64 bit machine
and it's not going to work i'm afraid
i don't have time right now to work out the best strategy for supporting 64 bit
it's failing at the point it's trying to load my 32 bit support dll, sadly a crucial part
dunno whether it's possible to run in 32 compatible mode?
Fixes: 382
No problem. I have a 32 bit XP machine so I'll have a play with it on that.
It's something I've been interested in playing with for a while now.
bluewhale
Quote from: Strat
i've changed the build to target x86 so i've read 64 bit world will now sandbox it as a 32bit app from end to end
would be interested in whether it works...
also did a bit more work on the chroma key code to make a bit easier to configure
