satnav or gps
Fixes: 415
Re: satnav or gps
Shutter I wouldn't have thought you of all people would need anything more than this Wink Smiley
Customer and Forum Moderator. Windows 10 Firefox 74.0 (64-bit)
Life is tough enough without adding Linux into the mix.
Fixes: 35
Re: satnav or gps
Quote from: pierre_pierre
thought I said that in answer 3, I have an old one will see if that give OS
the eTtrex modles can be found on www.garmin.co.uk/etrex
@ Pierre, your post, number FOUR, did include the word Etrex.... but very little other information,.... the rest was just smoke and mirrors and not a lot of use... Cheesy
Fixes: 35
Re: satnav or gps
@ strat.... yes, indeedy !... what every good pirate captain should have.... Grin
Unfortunately they are only any use at noon GMT,,,,,... and not much good at night (unless you can see, and recognise, the relevant stars to shoot ! ! !)... Cheesy
Re: satnav or gps
if you didnt know what eTrex was, why didnt you look it up
there is an old expresion, you can lead them to water, but not make them drink
Fixes: 35
Re: satnav or gps
P`raps that`s why I get the `ump.... when I only get half an answer to a query  Cheesy Cheesy
Re: satnav or gps
why should I have to look up all the details and waste an hour doing it, gave you the clues and you couldnt be bothered
Fixes: 415
Re: satnav or gps
Come on you two...let's call it quits before it goes too far Lips_are_sealed
Re: satnav or gps
@shutter - just received email from Morgan and they are doing a cheap sat nav
http://www.morgancomputers.co.uk/product_detail/12506/Foehn-Hirsch-3-5-Foehn-Hirsch-V3-GPS-SATNAV-UK...
Fixes: 35
Re: satnav or gps
Thanks for that one, nadger,.... will see if it can give the co=ordinates, as it is geared up for car navigation,  (even telling you which lane to get into)... but you only need to keep right on the canals ! ...
(opposite rule of the road ! ! )..
Have bookmarked the page, cos it may have some other stuff I might be interested in ...
. Cheesy
