rsi prob
- General Chat
- rsi prob
rsi prob
rsi prob
21-09-2008 12:56 PM
bit of advice needed please from anyone who has had an operation for rsi.
internet is not helpful [ no uk org since 2004 typical ] have seen dutch site but it seems to run ring -a- ring -a- roses around their topics.
would like to know if able to use fingers, soooon.
also was it succesful.
i have had cortisone injections [ just had one ouch-ouch ] that aren't now doing the trick. they do get rid of the pain waking me up at night tho'. doctor said that he expects better things from the one last week. suggested the op but having a hand out of action would be something else
i did not get this with computer job. think that it stemmed from when i fell over and broke a knuckle.
thanks in anticipation.
Re: rsi prob
Re: rsi prob
21-09-2008 1:51 PM
Re: rsi prob
Re: rsi prob
21-09-2008 2:17 PM
your site seems very good and plenty to explore.
looked at site of the clincs in Brighton and London but as i live on the fylde coast that will be a no-no. they seemed very good too.
will have to see how i go on before putting myself out of action. thanks for that . better site than mine. very grateful.
says to rest . fat chance. am off in the garden now .
Re: rsi prob
Re: rsi prob
21-09-2008 3:09 PM
Re: rsi prob
Re: rsi prob
21-09-2008 7:30 PM
i do have arm and wrist flat on the desk and wear a elastic sport -support.
have the support from the hospital when originally broke the knuckle but that seems to have wood up the middle. cannot use the mouse with it on.
on reflection i did type years ago as a telegraphist at the gpo but do not think after all of this time that it would show up now.
will have to see how things go.
just wondered if anyone had had the op. nothing like info from the horses mouth so to speak.. thanks
Re: rsi prob
Re: rsi prob
22-09-2008 12:04 AM
It could be any tablets you take making it worse. I had a similar problem this year but it effected my elbow shoulder which like you I couldnt move and was painful. They gave me diclofenics and things went from bad to worse my joints swelled up so they gave me stronger tablets and then they found I was anemic. I did some research on the net.
I went back to the doctor and asked why my joints swelled etc and she admitted its was a side effect of the tablets. I stop taking them and within a couple of weeks I was fine I just took an odd couple of ibuprofen every now and then when I was in pain. The other main things is drop any support that weakens the muscles and makes it worse as one of the main problems is muscle wastage as you cant use them.
Do as much exercise of the joints as you can especially stretching as this makes all the difference. Us warm pads and ice packs as often as you can.
A lot of it is the joint forms a scab and this is why its painful and you cant use it as the scab stops the movements one of the only ways to cure it sometimes is to force the joint to move which breaks the scab off they do it when you are asleep takes 2 mins
Re: rsi prob
Re: rsi prob
22-09-2008 12:16 PM
i do have arthritis tho'. it moves about.. have a lot in my back . think from lifting my husband. he was in a wheelchair for 16 years and just had use of lower right arm... have very little at the mo. take 25mg atenolol then purchase glucosomine and omega 3.
my doctor does acupuncture and have had at times too .. have you tried that . ? i have not lost use of my wrist.. just numbness in the fingers and pain with it if that makes senseand up the arm
what you have had must have been very painful..
thank you for contacting me will see how i go on now. think the doctor is expecting miracles.
window cleaner is here so bye for now and thankyou.
Re: rsi prob
Re: rsi prob
22-09-2008 2:32 PM
Re: rsi prob
Re: rsi prob
22-09-2008 2:36 PM
http://www.mayoclinic.com/health/numb-fingers/AN01323
Re: rsi prob
Re: rsi prob
22-09-2008 2:52 PM
Re: rsi prob
Re: rsi prob
22-09-2008 7:35 PM
thank you for that site but don't think it is raynards as the fingers don't go white. have poor circulation so the optician says.
a lot of things aggravate the hand really. the hand hurts if i hold a newspaper up to read and just got little feeling when holding anything. the pain there tho'. can't cut hard things like carrots etc.
@ artmo the doctor did suggest i would need investigation of the nerve if the injection didn't last.. it might be carpal tunnel on looking at it. there seems to be so many things that could cause the problem.
thank you both for bothering.
keeping my fingers crossed. am on the move a lot. and a young dog seems to think that i was put on this earth just for him...
wouldn't mind being thirty again
Re: rsi prob
Re: rsi prob
22-09-2008 11:31 PM
As a general rule you need to exercise as much as you can even if it hurts loose weight if you are overweight, try ice and heat pads regularly, plenty of fluid and eat loads of veg fruit etc. Mine is ok now its gone away but tends to come back with wet weather may last a month then be ok again for 6-9 months
Re: rsi prob
Re: rsi prob
23-09-2008 11:39 AM
glad that you are currently free of pain. you do seem to have it rough and the trouble is you keep expecting it back. you appear to have more pain than i...
yes weight okay thanks steady 9.2/4. .. and diet okay . and have house ,, garden and a dog to keep me on the move..
hope that your wife does not have too much trouble with the raynards.
i don't think that i will get rid of the funny feeling in three of the fingers and the thumb. just hope that this last inj lasts re the actual pain.
lovely morning . am off out with the dog for one of his walks then he is going to have a bath [he runs off when he sees my plastic apron]
Re: rsi prob
Re: rsi prob
23-09-2008 12:32 PM
Re: rsi prob
Re: rsi prob
23-09-2008 2:44 PM
