"'Ullo John! Gotta New Mobile?"
Minivanman
Aspiring Legend
Well the Mrs has anyway, and it's a Samsung A50.
Because along with so much else she also wants to use it as a sat nav, can anybody recommend a decent car phone holder, as checking on line there is such as wide choice - so a greater chance of buying rubbish.
Because we drive an 06 Fiesta it's probably going to have to be one of those sucker ones that stick onto the windscreen. Seen the magnetic mounts which one of our daughters have, but they don't seem to do those for the sucker type - and I really don't fancy glueing anything onto the dashboard!
Cheers Thumbs_Up
Don't limit the friends you haven't met with arguments you'll never have.
6 REPLIES 6
DaveyH
Champion
Fixes: 12
Re: "'Ullo John! Gotta New Mobile?"
Kenu Airframe.
Been using them for so many years now I wouldn't consider anything else
https://www.kenu.com/collections/car-mounts
Minivanman
Aspiring Legend
Thanks, will check it out.
shutter
Fixes: 47
(altogether now...... Awwwww !  Azn  )
Even Araldite succumbs to the heat, so it may not be there for long in this weather.
Minivanman
Aspiring Legend
@shutter
I only mentioned the year in case somebody suggested a holder that attached to the air vents which on an 06 model would be really difficult?
Smiley
RobPN
Fixes: 5
@shutter
Well if Araldite won't hold it, perhaps this will work?  Wink
57535472-hammer-and-nails
Fixes: 187
I have one for my satnav that consists of basically four bags of what I think is lead shot. It sits on the dasboard and never moves. No sucker, magnets, glue or nails, just non slippy bags of lead  and gravity. Look up weighted friction mounts.
