"Smart" meters!
- General Chat
- "Smart" meters!
"Smart" meters!
19-03-2016 8:30 AM
Courtesy of today's FT..
Quote GCHQ has intervened in the design of an £11bn nationwide system of smart energy meters to secure them against attempts by hackers to crash the country’s power grids.
The agency built in additional security measures for the UK metering system after discovering loopholes in meter designs in use abroad that it believed could pose a national security risk if rolled out in Britain.
The communication channel between each meter and the utilities operating them was designed to be encrypted. But the encryption key, the code used to unscramble the data each meter sends and receives, was the same for all of them.
GCHQ is helping the Department of Energy and Climate Change securely design the new metering system, one of the UK’s biggest IT projects in a generation. Energy companies have already installed about 2m of the 53m smart meters due to be rolled out in homes and small businesses across the country by 2020.
“The guys making the meters are really good at making the meters, but they might not know a lot about making them secure. The guys making head-end systems know a lot about making them secure, but not about what vulnerabilities might be built into them,”
Re: "Smart" meters!
19-03-2016 8:59 AM
I suspect there will be more issues so I am fighting having a smart meter
I recently changed supplier and during my sign up I was asked do you have a smart meter? When I said no he said good then we won't have a problem transferring you
To be is to do - Kant
do be do be do - Sinatra
Re: "Smart" meters!
19-03-2016 10:22 AM
As can be seen from my online account below I've had 2 'Smart' readings on the gas meter since installation.
The latest 2 readings were requested by nPower and supplied by me in order for them to supply me with an accurate statement
Quote 16/02/2016 Customer read, Electricity 1242
16/02/2016 Customer read, Gas 523
15/12/2015 Estimated read, Electricity 834
14/12/2015 Smart read, Gas 222
08/12/2015 Estimated read, Electricity 741
07/12/2015 Smart read, Gas 191
07/10/2015 npower read, Electricity 0
07/10/2015 npower read, Gas 99999
You had a new gas and electric meter put in on 07/10/2015
I don't know how secure my meters are but if the country is plunged into darkness then I apologise in advance.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
Re: "Smart" meters!
19-03-2016 10:26 AM
Re: "Smart" meters!
19-03-2016 8:49 PM
Re: "Smart" meters!
20-03-2016 4:19 AM
Re: "Smart" meters!
20-03-2016 7:34 AM
Re: "Smart" meters!
20-03-2016 8:23 AM
The smart meter doesn't prevent a consumer from spreading the cost of their utilities throughout the year just as they do now.
Re: "Smart" meters!
20-03-2016 8:40 AM
Re: "Smart" meters!
20-03-2016 9:06 AM
Quote from: artmo Eventually all households must have a smart meter as it's the law. All households must have one fitted by 2020.
I'm well aware of that, artmo, but until they solve the problem of 'smart' becoming 'dumb', it seems a pointless and expensive exercise.
Re: "Smart" meters!
20-03-2016 9:35 AM
Not quite true. From https://www.gov.uk/guidance/smart-meters-how-they-work
Quote Smart meters will be rolled out as standard across the country by 2020. But there will not be a legal obligation on individuals to have one.
Re: "Smart" meters!
20-03-2016 9:43 AM
Re: "Smart" meters!
20-03-2016 9:50 AM
That's real good news. It means that prior to that we MUST have a reliable mobile signal in the village.
Re: "Smart" meters!
20-03-2016 9:53 AM
Re: "Smart" meters!
20-03-2016 10:13 AM
[quote=http://www.energysavingtrust.org.uk/blog/2015/02/whats-behind-smart-meter-delay]“Although the initial installation of smart meters is carried out by whoever is your energy supplier at the time, the intention is that the data generated is under control of the customer rather than the supplier. Once the DCC is up and running, when a customer switches supplier the new supplier will be able to request and receive data from the existing smart meter."
He adds that because smart meter data is not owned by the supplier, it can be shared with third parties who might come up with innovative services for consumers. Nick says:
and it's the delay in the implementation of this database that have pushed the roll out of smart meters by 2 years.
With Smart Metering I believe thief of electricity and gas will be highlighted as generating companies know how much is going through a sub station and how much is being used by properties connected to that sub station.
