pocketgpsworld
Fixes: 154
pocketgpsworld
Just looking for a bit of feedback if anyone uses the speed camera database - worth the money?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
MJN
Re: pocketgpsworld
At the risk of becoming a candidate for the Most Unhelpful Reply Award 2014 I used to use it when it was free (nearly 10 years ago now!) and it was good then. Don't know how the change to a subscription model has affected things either way though.
Fixes: 9
Re: pocketgpsworld
And another unhelpful answer,
Had this system free on my old gps but it simply got on my nerves as I made a loud ding every time a camera was near or in an area where the police might be using speed guns, not sure if it worked on motorway cameras that record your average speed between 2 cameras.
However my current gps shows the current speed alongside the speed restriction in that particular area.
Fixes: 154
Re: pocketgpsworld
thanks anyway Smiley
