pcs and mobile phones
owlguard
Hi everyone,if i use my mobile while sitting at the side of my pc,should it affect the mobile,reference reception etc.
                                          kind regards ray.Oh and up the Owls.
Re: pcs and mobile phones
I wouldn't have thought so. You might get some funny noises from your speakers though immediately before you receive a text message or phone call.
owlguard
Thanks for that input mate-regards ray.
Whilst I agree that turning BT off if you don't need it is generally as good idea a it saves battery power, for what it's worth I use a Mac which has both 802.11g (for the internet) and BT (for my mouse and phone) running concurrently, with no ill effects.
Fixes: 58
Quote from: Be3G
Your battery is not the only thing you may save.
Customer and Forum Moderator.
Fixes: 10
We had a discussion a bit back about not having you mobile too near your mouse (pointer suddenly jumps off to somewhere random). Since I took that advice I haven't seen that happen - my mouse is a standard optical wired.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
owlguard
Sorry to come back so late but thanks again to the rest of you guys for the interesting points,education is all to save you from any possible messups in the future,thanks again ray.
