over reliant on clueless computers
magnetism2772
ie looking into some computing programming
i saw this line;
y= y;    /well of course it does
here are codelines written by a programmmer with lots  experience , who knows how dumb computers are ,and wants to make sure , as in this line
let x = 209;
let x = 209;
some decide they need to program a function to answer a multi choice question
as in the following code lines below,
int val;
get(val);
if  val == 1 | 2 | 3 /* multichoice*/
do convert_Intoi(val);
else
return 0;
int convert_Intoi(val)
if (convert_Intoi(val))== 1 return 1;
if (convert_Intoi(val))== 2 return 2;
       if (convert_Intoi(val))== 3 return 3;
else(return 0);
   return  0;
what the  hell ....?
another stupid case where computers create redundancies
Re: over reliant on clueless computers
Hmmmmm, what language are they?
Most could easily be correct, validating an uncontrolled/unvalidated keyboard input for example and delivering a well-defined set of internal numeric values.
As an ex-programmer it never ceased to amaze me how many lazy programmers didn't properly validate data, wrote rather brief code and frequently got the wrong answers.
magnetism2772
if I asked I'd likely be told its  'english'
and probably its children during an  IT lesson at school Grin
Fixes: 58
Programming time = 30% coding....70% idiot proofing Roll eyes
Customer and Forum Moderator.
magnetism2772
yes Strat
very true
for any input any  of the idea of the output ?
the whole section of code  appears  redundant
input = output in this case
ie input 1  the output is  1 etc
magnetism2772
as Its the work of some children at IT class
magnetism2772
edited: code
Quote from: Strat
I work on 10:90 ratio, then often find I've missed something obvious.  Shocked
magnetism2772
its written in C
anyone is welcome to create a  program to test the function convert_Intoi()
and test its  output  for inputs of 1 or 2 or 3
Cool
itsme
Quote from: Strat
Programming time = 20% coding....50% idiot proofing Roll eyes
As a hardware designer Programmers use to wind me up with their attitude of 'If there's a bug we can update it later'. No you can't if it's firmware.
So to me it should be.
Programming time = 20% coding....50% idiot proofing and 30% Verify and Validating
Fixes: 20
int convert_Intoi(int val)
  else(return 0);
My C us a bit rusty, but this seems to be an endless recursive loop. It is calling itself then calling itself ...
itsme
Don't think so but I need to get the books out to confirm  Grin I think it's an If else statement.
magnetism2772
==  this is the 'equal too sign' and  not the make it  equal sign  and  the function will return 1 or 2 or 3  only if the  value is equal to an input of 1 or 2 or 3
=    this is the  equal sign
magnetism2772
as a little exercise perhaps a c programmer who reads the post
could make a (simple ?) test program
to check the convert_Intoi() function  and test it for input of 1 or 2 or 3
Lurker
Presumably there are 4 possible outcomes.
1,2,3 or 0
Dunno why it seems like a strange thing to write - there are lots of uses (and places where identical logic is used)
