mobile phone connection problem
Fixes: 19
I am on T-Mobile, and have an Italian friend staying with me at present.  His mobile will contact my mobile, yet I cannot contact him .... His number starts off 3313******
I have tried it with a 0 to start, but I get a message saying that  T mobile is not accepting calls to this number...
Can anyone suggest how I can contact him on his mobile.....
(When I use the 3313 number on BT landline, it says the number is not recognised)
(When I use a 0 to start.... there is no message from BT and no connection/dialling/ringing tone)
pierre_pierre
Re: mobile phone connection problem
you have to put +0039 in front of his number then the call get routed to Italy and  back to you, cost a small fortune
Fixes: 19
OK Pierre, Thanks . I will try it...
Cheers
Fixes: 5
Shouldn't that be either 0039 or +39, with the 00 and the + basically meaning the same thing?
itsme
On mobiles you should only need to enter +39 (the + is the equivalent to 00) and on landlines it's 0039
Fixes: 21
33 is the ISD code for France or just the start of his number more likely if the number of * you've put correctly shows how many more digits in his number.
So from a mobile you probably need to dial +39 then number, from a  BT landline 0039 then number.
Edit: well with more than 1 reply saying the same thing, it should work!!
itsme
One thing to note if you travel is to store the numbers in the mobile in international format i.e. +44. So when you are abroad and phoning back to the UK you don't need to edit the telephone number. It's also worth knowing that + will work in all countries and 00 will not. In the USA to dial an International number it's not 00 but 011.
IIRC when you call an Italian number you have to include the 0 at the beginning of the number. +39 0721 123456
Normally calling an international number you would drop the 0
BTW get your friend a free PAYG sim card and stick it in their phone
ASDA and Tesco do them
Calls on the Asda one are only 0.08ppm
No you dont include the 0 - that's the whole idea of the +39
the plus means use the following country code
the uk of course is 44
If you travel overseas - you should store all your numbers like +44 2345 789012
so you can call them easily
Fixes: 19
Hi Guys.
Thanks for ALL the info... I tried the 0039 on the BT landline phone, and it worked. so will program my mobile with +39 before his number.....
Cheers
pierre_pierre
the Tesco PAYG sim is currently £1.25 if you also put some credit on it
Fixes: 21
Mal, things are different in Italy apparently http://www.slowtrav.com/italy/instructions/dialing.htm
You don't drop the leading 0 on city codes, but there is no leading zero for mobiles which all begin 3 (see just over halfway down the page).
Really Chris - well that is news to me - thanks for the info. Strange - but then the Italian's have some unique ( many nice ) characteristics.
sorry - I didn't thoroughly read all the thread before posting. I've been using GSM phones ever since they went live, as I used to work for Nokia.
