members centre
members centre
hi is there a issue with the member center  where you cannot change the password to one of your own , it seems that some advisors know of a issue and some do not  thanks
2 REPLIES 2
Fixes: 964
Re: members centre
Hi there.
We do currently have an issue where you’re unable to change your password via the change password tool in your member centre, however a workaround for now is to use the forgot password tool here: https://www.plus.net/forgotpassword/
Hope this helps.
Re: members centre
hi many thanks for your advice at the moment i have been told to use [Removed] as password although we have been with them for around 2 yr never had to change password then about 2 weeks ago i could not  log into a eBay account and plus net  which i found strange contacted plus net told them what happened some advisors say no problem others say other users had the same issue, have plus net got any idea when it will be fixed as tech are blaming my PC thanks
Moderator's note by Dick (Strat): Personal information removed from a public forum (to an area that staff can see).
